Thanks for your answer. The static motor resistance is 15 ohms measured in multiple spots of the motor rotation with a DVM. These motors will be used only to spin some disks and hold position with no load so the current resolution may not be a problem unless it causes too much jitter. I'll try it as is and maybe try a parallel load resistor if the jitter is too much. Using voltage mode will be a last resort.
AZ
Message: 13250 |
Date: 5/9/2016 |
Subject: Re: Snap amp minimum current |
Hello Tom:
I have been running those low current motors directly with the SnapAmp Peak current set to 10 and they work fine. No excess jitter or other noise. I did not add the parallel load resistors. I have the Pgain set to 3. Dgain at 300 and this delivers very acceptable holding torque and stability with a 100 hz low pass gain filter. These motors have ferrite beads on the motor leads and the beads do get warm to the touch. The motors get warm also but just barely enough to feel the temp difference from ambient.
I do have a couple of other issues that came up. The motor actual positions are offset by quite a bit when in position and this offset distance is consistent no matter the motor position. If I DisableAxis, then EnableAxis the motor will shift the distance of this offset each time. On an analog drive I would simply adjust the input offset adjustment to take care of this but is there a way to adjust the SnapAmp output offset to eliminate this?
The second issue has to do with the EnableAxisDest(0,X) command
I am using version 4.32 now and have used version 4.31 and 4.30 previously. In 4.31 and 4.30 when I used this command, it would preset the current axis position to the value of (X) with no motion. In 4.32 it commands a move to that position (X). Am I missing something or did this change?
Message: 13252 |
Date: 5/9/2016 |
Hi AZ,
Adding some I (Integrator Gain) should force the average error to
be exactly zero. Start with a small number such as 0.00001.
EnableAxisDest(0,X); will enable the axis and set the target
destination to X. If X is not the current encoder position then
this would normally cause a violent motion to move the encoder
position from wherever it is to X. So whether there is motion or
not will be determined by where the Axis currently is Positioned
at. I'm not aware of any change in the behavior over those
versions.
On 5/9/2016 7:20 AM, az@...
[DynoMotion] wrote:
Hello Tom:
command
Message: 13253 |
Date: 5/9/2016 |
OK. How can I preset the current axis position in Kflop without Kcnc running to a value other than zero? I can't seem to find an example of this other than the G code fixture offsets in Kcnc. Would I set the commanded position or set the actual current encoder position? Would I have to do it with the axis disabled especially considering that the actual motor position would jump to the offset as mentioned before?
AZ
Message: 13254 |
Date: 5/9/2016 |
Hi AZ,
Depends a lot on what you are trying to do and what is important
to you.
The normal technique is to enable the axis and set the target
destination to where the Encoder Position is currently reading
with:
EnableAxisDest(0,ch0->Position);
This method maintains the correct Axis Position even after a
crash, Drive disable, drift, manual movement, etc as the system
will still maintain a valid Encoder position regardless of whether
the axis follows the desired Commanded positions or not. This is
what EnableAxis(0); does for Servo Mode Axes by default.
This method should enable the axis gracefully avoiding any
violent motion because the target servo position is set to where
it actually is.
Adding the I gain should make the Commanded position and Measured
Encoder position very close (average difference will be zero
except for any servo dither). But there still might be some
movement depending on the servo dither, if/how long the axis has
been disabled, drift, manual movement, etc... If this is a
problem you might save the last commanded destination, enable the
axis, then perform a controlled movement back to the last
commanded destination. For example:
double SaveDest=ch0->Dest; // Save where we were last
commanded to be
EnableAxisDext(0, ch0->Position); // enable the axes where we
are
Move(0,SaveDest); // move back to where we were last commanded
while (!CheckDone(0)) ; // wait for the motion back to complete
On 5/9/2016 9:50 AM, az@...
AZ
Message: 13255 |
Date: 5/9/2016 |
Tom: I think I may have over complicated my question. What I want to do is set the current position to another value while not moving the axis. For example: After the axis homes, I can zero the axis so the current position is 0.000. I want to set that homed position to be 14.400 inches instead of 0.000 without moving the motor. Can I do that? AZ
Message: 13256 |
Date: 5/10/2016 |
Me, too. When I did some experimenting for configuring my machine in closed loop mode, which I abandoned, I stumbled in this issue too. After homing my machine is in a position that I consider to be (x,y,z) = (0,0,90). It would be nice if the EnableAxisDest() function would accept a parameter for telling it which position the current position is.
If I remember correctly - but it was so many months ago so I may be wrong - I had to set the position via the Kmotion application every time after homing with KmotionCNC, as I couldn't find an equivalent function for doing it in C.
Regards, EC
Message: 13258 |
Date: 5/10/2016 |
Hi Guys,
I may have misunderstood the problem, but can't you use an offset
such as G92 to set the homed position to another value?
David.
On 5/10/2016 3:21 AM,
ericnc@... [DynoMotion] wrote:
Me, too.
EC
Message: 13260 |
Date: 5/10/2016 |
To set the current physical position to some desired (zero or
non-zero position) do the following:
DisableAxis(0); // disable the axis so we don't jump/jerk when we
change the encoder position
ch0->Position=90.0*Counts_per_mm; // Set whatever machine
position you would like for that physical position
EnableAxisDest(0,ch->Position); // enable the servo with that
position as the target destination
On 5/10/2016 12:21 AM,
Me, too.
EC
Message: 13261 |
Date: 5/10/2016 |
oops should have been:
EnableAxisDest(0,ch0->Position); // enable the servo with that
On 5/10/2016 12:18 PM, Tom Kerekes
(zero or non-zero position) do the following:
when we change the encoder position
machine position you would like for that physical position
that position as the target destination
On 5/10/2016 12:21 AM, ericnc@...
[DynoMotion] wrote:
Me, too.
(0,0,90).
for doing it in C.
EC
Message: 13265 |
Date: 5/12/2016 |
Thank you! This should fix it, will try it next time I'll put my hands on the machine. EC
DisableAxis(2); // disable the axis so we don't jump/jerk when we
ch2->Position=90.0*Counts_per_mm; // Set whatever machine
EnableAxisDest(2,ch2->Position); // enable the servo with that
Message: 13267 |
Date: 5/12/2016 |
I tried it and it worked. I didn't realize that the "*Counts_per_mm" was to be defined by me so I originally got an error. I just
put in a position value without that portion of the statement and it works splendidly.
Thanks Tom.
AZ
Message: 13271 |
Date: 5/12/2016 |
Yes you can if you use the KCNC. But In my case I'm not using KCNC I'm developing a controller in the C code with a PC running VB.
AZ
